Sada je Pet tra 19, 2019 4:42 am
Odgovori  [ 9 post(ov)a ]
SL 300 24V- radio kod
Pridružen: Ned srp 01, 2007 12:53 pm
Postovi: 1304
Lokacija: SPLIT
Ime: Davor
Moj auto: 500 SEC i SL 560 i SL 300 i SE 280 + puno ostalih
nakon dugo vremena sam upalio SL-a i kad sam ubacio radio kod na ekranu mi izbacuje E 2, što to znači, ima li tko kakva iskustva, nisam siguran dali mi je to već bilo jer sam mjenjao tvorničko pojačalo,tada je također bio nešto ispisivao dok ga nisam zamjenio, nakon tog je radio normalno zadnji put kad sam ga vozio
mercomaniak
Pet ožu 27, 2015 11:27 pm
Postovi: 1191
Godište: 2010
Moj auto: :
W169 200 CDI Avantgarde
W639 Vito - putni
W204 220 CDI Avantgarde
Googlanjem sam vidio da se problem javlja ljudima koji nisu dugo koristili auto.
Evo jos nekih rijesenja:
"E2"or "E3" (Without CD Changer)
1 Input Power to the RECEIVER UNIT (Trunk mounted) is missing, Check with volt meter to test for 12 volts
2 Fuse of the RECEIVER UNIT (Trunk mounted) is open, Replace it with 7.5 amp fuse.
3 The BUS CABLE (gray colored) that connects to HEAD UNIT(dash mounted) to the RECEIVER UNIT(trunk mounted) is not connected or is defective.
4 RECEIVER UNIT(trunk mounted) is defective.
"E2 or "E3" (With CD Changer)
1 Input power to RECEIVER UNIT (Trunk mounted) is missing, Use a voltmeter to test for 12 volts
2 Check the RECEIVER UNIT for an open fuse and replace with 7.5 amp
3 Input power to the CD CHANGER (Trunk mounted) is missing, check with volt meter to test 12 volts
4 BUS CABLE (gray colored) is defective or disconnected,
5 CD CHANGER is defective, Disconnect the CD CHANGER from the HEAD UNIT, if the E2 code disappears, Replace the CD CHANGER,
6 RECEIVER UNIT (Trunk mounted) is defective.
Koliko sam shvatio, problem je do pojacala, ili ne prima struju ili nesto vezano uz njega.
Ja bi probao otpojiti bateriju, pricekati 15 min, pa ponovno spojiti (ali samo ako imate kod za otkljucavanje radija !)
Sub ožu 28, 2015 1:16 pm
Postovi: 1304
Lokacija: SPLIT
Ime: Davor
tako mi je bilo i zadnji put, pokušaću opet doći do pojačala, valjda nije i ovo izgorilo
mercomaniak
Sub ožu 28, 2015 1:25 pm
Postovi: 1304
Lokacija: SPLIT
Ime: Davor
proradilo nakon resetiranja
mercomaniak
Sri tra 01, 2015 11:05 pm
Postovi: 1191
Godište: 2010
Moj auto: :
W639 Vito - putni
xnet5524 napisao:
Odlično 8)
Šta vam znači restartanje, vađenje akumulatora?
Čet tra 02, 2015 8:00 am
Postovi: 1304
Lokacija: SPLIT
Ime: Davor
ne, ali sličan đir, otpojio pojačalo u više navrata s napajanja dok nisam uspio upaliti radio tj dok nije prestao pokazivati grešku na ekanu radia, uglavnom sad radi ali kakva korist kad će opet na ležanje, sad je 635 CSI na redu za voziti
mercomaniak
Čet tra 02, 2015 9:10 am
Pridružen: Sub ruj 20, 2014 1:45 pm
Postovi: 564
Ime: Mladen
Godište: 1969
Moj auto: W 124 E320 95.g.
Ostavi radio da radi non-stop :rotfl:
Svoju Zvizdu slidin, lipo san ti reka
Čet tra 02, 2015 3:28 pm
Postovi: 1304
Lokacija: SPLIT
Ime: Davor
jedino rješenje, ali nažalost nije mi blizu, auta su mi po cijeloj županiji onda kad uvatim vremena pali se jedan po jedan, e da je hangar ko što si ameri mogu priuštiti, al dok je rodbine, prijatelja i njihovih praznih garaža dobro je, svaki put kad me zovu neznam jel selim auto il zovu onako, da me čuju, ajme :banghead:
mercomaniak
Čet tra 02, 2015 5:09 pm
Postovi: 1191
Godište: 2010
Moj auto: :
W639 Vito - putni
Lijepo je to kada imate šta seliti :bye:
Pet tra 03, 2015 7:41 am
